DC lvl 3 problem
If it still smells like its cooking, less with the gains on the amp. and use the control on your headunit instead.
could it be bad electrical clipping my amp? battery is refurbished and over 5 years old
but the kid i bought it from had it in same box, and on a hifonics 1000 watt, and it slammed, no clipping or bottoming out intill i put it in my truck?
Different vehicle, different results. Bottoming out isn't a result of different installs, clipping, old batt, etc. It's a purely too much power kind of thing. The difference in spl is from changing vehicles and maybe not having it set up in your truck for the best results. Cabin gain is going to be different in each vehicle, so you'll get different response curves based on that as well.
What vehicle was it in before, and what truck do you have? Also, how it is set up in your truck?
It could be running low voltage thus not putting out as much power as you think it is, in return you turn the gains or volume up and causing it. If you have access to a dmm I'd check your voltage at full tilt at your amp and see what its reading. Other than that I dont know:crap:
And if you cant find anyone with a dmm you can get one at wally world or somewhere like that for ~$10
was in a 1999 grand prix, i got a s10 extended cab, 3.5 cubic foot box, i think 32hz, port firing up sub facing up
Uploaded with ImageShack.us
well, voltage on my s10 goes from 14ish to like 10 11ish
Yeah you dont want to ever be dropping below 12. You have the big 3 done? Might want to get that battery upgraded too while you're at it.
plan on red top, but would that casue it, i fixed bottoming out i tihnk, but i still smell cooils burning and its not even loud or turned up high
Wouldnt cause the cooking but it will cause harm to your amp. I dont know why the sub is smelling, especially since it should be broken in by now. The best advice I can give is try to find someone with an oscope to peek at the waves and see if your amp is clipping or if the sub is just bad.
but i sold it to him i was bumping it fine for over an hour before he came and got it on my amp and then as soon as he hooks it up it starts to smell
that meakers no since
but i sold it to him i was buming it fine for over an hour before he came and got it on my amp and then as soon as he hookes it up it starts to smell that meakers no since
Might be something wrong internally with his amp then. But it shouldnt be smelling like that. I know its a hassle and all but maybe try putting it back on your amp and see how it smells. or switch your amp in his truck real quick to see if it does. Easiest way to figure out if the amp is the problem or not.
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
695
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
SpedBoy
SpedBoy
Brighton, Mi
littleharv93
    May 22, 2024
    May 22, 2024
