detailer broke my sub. replacement options?
I took my car to get detailed the other day and it got punctured by one of the detailers there. they told me they would replace it but my sub is quite old and id like it replaced with todays equivalent. its an orion p1202 and i cannot find any information on this sub. Any ideas?
do you have a picture? a puncture can almost always be fixed, unless it needs to look perfect. Or are you trying to take advantage of the situation and get a newer sub because you can?
Amazing goop, Works like a charm, sub will work like new. STILL get that new sub from the detailer since it is still their fault and they own up to it.
If you are a nice guy, you can just have them pay for the amazing goop used for the repair.
what about a sundown audio sa12? how does this compare to the sd 12 d4?
If you're looking for some good quality sound on not much power I would definitely take a look at the dcon. From what I can tell, sundown doesn't offer a 12" SD. The SA-12 is a solid sub but your amp won't do it much justice. Those SA's can handle a good clean 1k to really hit their full potential.
Dcon is by far a better option for that amp
well i found a used sa 12 for 100 bucks. the mounting depth is 6 1/2 inches and the mounting depth i have to work with is just a little more than that. the box is 8 inches deep but id like to cut off about an inch
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
285
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
464
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
576
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
907
smidge710
smidge710
camarillo, ca
smidge710
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
