detailer broke my sub. replacement options?
Looked like somebody honestly stepped right on it or used it to hold their weight up on one of their knees. it ripped around the edge, and punctured a couple holes from the grill i had over it popping out and ripping into it
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
131
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
284
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
463
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
574
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
905
smidge710
smidge710
camarillo, ca
smidge710
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
