3 out of 4 speakers won't work
  • 4
Robertz
CarAudio.com Newbie
I have a 2005 Honda Civic LX and after purchasing it earlier this week I found that I had to enter a code to start the radio. I did that but three out of four speakers don't work. I fooled around with the balances too. No sound at all. 2 rear speakers and the passenger side speakers are silent.Seems like too much of a coincidence for three blown speakers.Any help?
Check to see if the wiring harness between the body and door isn't cracked. A lot of times the driver side harness will crack and break over time because that door gets used the most. I'm replacing both of them in my Jeep this weekend for the same problem plus my windows quit working.
nbs check for any accident reports, front end near fenders or door replacements, piggy backing off previous reply, could be an open circuit issue with a door harness, or was gonna say additionally check splice connectors near impact points for corrosion/buildup on connectors. my best guess.
Not really, stock car speakers are extremely flimsy from the start and yours are almost 20 years old! I have no trouble believing the bloke who blew 1 didn't just keep cranking it to make up for the 1 that was out and broke another two. What's surprising is that ANY of them work.
Civic is pretty simple to get into the doors either way, pull a speaker and test it with a known working receiver or even use a couple small bits of wire and a AAA flashlight battery to quickly tap the + terminal of the battery to one speaker terminal and the - terminal to the other speaker terminal and you would hear a pop if the speaker functions. It is very likely you'll pull the speaker and it is half falling apart from age though and you won't be surprised it isn't making sound.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
169
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
91
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
997
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
322
Robertz
CarAudio.com Newbie
Robertz
Baltimore Maryland
hispls
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
