Do I have to run an Audio Control LC2i off of the stock head unit?
acura3.2tl
CO
So I want just a sub in my 2021 Kia Forte GT. It has the Harmon Kardon stereo with the subwoofer. How do I go about hooking up the Audio Control LC2i to my stock head unit? If I am only running a sub off of the LC2i do I have to go through the head unit still or just hook it up to the stock subwoofer? Thanks guys!
Since my car has the Harmon Kardon stereo will there be a subsonic filter at like 40hz on the stock subwoofer? If there is a subsonic filter the new aftermarket sub is not gonna sound right is it?
That is where the AccuBass feature comes in. It corrects the subwoofer protection curve set into OEM radios. It claims to flatten the signal that the OEM reduces to protect from over excursion. I assume it will be the same for a subsonic filtered signal.
I'm running off the sub wires in a 2018 silverado stock system and the lc2i "worked" but It did taper off the low end, say everything below 30 or 35 hz was very lacking. I gave the kicker Keyloc a try and was honestly very surprised it brought back as much as it did. Now it plays much better at lower frequencies. Just bummed I'm stuck with a lc2i on my shelf.
Lmfao. So the other day you tried to argue it would cost $800 to do this but today it cost $100. I'm f*cking dying laughing
The other day I referenced what it would cost to bypass the entire amp. All of my speakers are still ran off the stock amp because that also handles door dings and blinkers. Without the expensive "kit" people end up amplifying their dinging to ungodly volumes. In my scenario and this op's we are only adding a subwoofer. And keeping the factory amp in place. So you can just process the signal from there. Cheers
Thanks for the update. Always good to hear about firsthand experience of a new product. Never heard of the Keyloc.
I hadn't either and took a shot at it because I was really disappointed after taking up room to install a 12 inch woofer in the back it still didn't sound right. I'm glad I tried it. Setup is a bit strange but kickers website and YouTube does a decent job explaining. You have to play test tones for the keyloc to analyze your available signal
Advice #2. Find out what your new subs enclosure is tuned to and set subsonic to 75%-100% of your box tuning. Mines tuned to 40hz, i set my subsonic to 34hz.
As far as your first question that will be in your audio settings. Im not positrive but I havent seen a stock amp that had settings on the amp like aftermarket. Theyre in the settings of the head unit.
But seriously, theres most likely NOT a SUBSONNIC SETTING. tHERE WILL BE A SUBWOOFER LEVEL SETTING AND BASS BOOST TYTPE PROBABLY. woops caps
LOL....after seeing many of your other posts/threads i think you are the last person on this website that should be giving people advice!! LOL
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
acura3.2tl
acura3.2tl
CO
Bellmeister
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
