Do i need a new Alt or Seccond Battery?
If you get the 250 amp alt you won't see any voltage drop and should be good. You'll still drop to low 13s or high 12s with a battery. Alts make the power you need, batteries just store it.
But I would recommend an AGM under the hood first if you haven't done so yet
There both correct dont do it you be sorry , or you can keep the starter and add a batt to the back with a run of pos/neg either 2 or 0 gauge fused at both ends of the pos , but if you just put the agm up front itll work too
So should I go with the Alt first?and then go from there? Or start out with like a xs 3100? can only buy one or the other at this point, being a college student i dont just have $$$ to blow. lol.
My voltage drop stopped when i installed my singer alt. I had agm up front and in back. I was running a rf t1500bdcp. I recommend singer alts never had a problem and never seen a bad review. Well except that guy who changed out the pulley Mike sent for the stock one.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
450
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
346
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
754
93Exploder
93Exploder
Turlock Ca
93Exploder
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
