Does the standard 6 and 12 spoke 18" baskets share same mounting hole size
  • 1
manyhobbies
I believe the 6 and 12 spoke 18" baskets share the same cut out mounting hole size but I havn't confirmed this as of yet, so can someone confirm this. I have 6 spoke baskets to measure off to cut the holes for mounting but I will be putting 12 spoke basket subs in and dont want a sloppy hole and what I mean by this is I dont want any play in it. These are the standard common traditional baskets.
From what I measured it appears to need to be 16 5/8" with the gasket. Thanks, Russ
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
339
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
988
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
955
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
manyhobbies
manyhobbies
Celina, Ohio
manyhobbies
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
