Dont think he knows what he's talking about....
Ok so i got a Image Dynamics IDQ10 V2 and a Kenwood KAC5204 off this guy on craigslist. He said they will work fine together.
Here's the specs on the amp:
2-channel car amplifier
60 watts RMS x 2 at 4 ohms (75 watts x 2 at 2 ohms)
150 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
selectable low-pass filter (80 Hz at 12 dB per octave)
Class AB design and MOSFET power supply
the sub is in an enclosure so I can only see the front of it. He says it's an IDQ10 D4 V.2. There is only one pair of banana inputs on the back of the enclosure....but i thought this was a dual coil.... wouldnt that put an 8 ohm load on the amp???
The spec sheet for the sub says:
250W RMS
and impedance of 2/8?? (i can't read it clearly so it might be 2/6)
I've been trying to learn the relationship between impedance and dual coils and wattage and all this ****, but it's extremely frustrating. Can someone please tell me if i can run this sub in bridged off this amp? He said to just wire it in bridged mode and it's fine...he seems to know what he was talking about on most stuff pertaining to audio, but on some other stuff i was just like "...the hell?"
Is this even gonna work? Please don't tell me to buy another amp just because this is a cheap one. I KNOW. I'm broke as hell and cant possibly afford another now. Please help a noob out before i blow this **** speaker up...
i know. i have read through this **** over and over again. Im not lazy but obviously im a moron. I'm aware of the diagrams out there and obviously it's not making sense even when spelled out to me. Can someone please give me a better answer than "UTFSE" as i've already been doing that.
With one pair of terminals on the enclosure, I'm betting he wired the coils in series for an 8 ohm combined impedance. That will be fine for that amp, but will cause you to lose about half of the power it's capable of - that 150W at 4 ohms might only be 75W at 8.
He's correct in saying it'll work, but it may not be enough output for you. Or it could be, try and see. But flexibility (and higher power) at different impedance loads is a main reason why most dedicated subwoofer amplifiers are single channel.
He's a moron....I opened it up and it's a D2, not a D4.
as for the wiring...the positive of one coil and the negative of the other are wired to the pos and neg's at the back of the enclosure. The neg of one coil is wired directly to the pos of the other... which i believe makes it wired in series?
Very simple pull the sub and look at the wires.
If both positive and both negative wires are bridged to the box connector it is in parallel or 2 ohm
If one positive and one negative are jumped and the remaining pos and neg go to the box connector it is in series 8 ohm
If you take a pic anyone here can help
If it's a D4, you'll be getting 120w @ 8 ohms out of the amp. A little underpowered, but that's perfectly fine and will still sound good. If it's a D2, you'll be getting 150w @ 4 ohms.
that would be 4ohms geting 150 watts on a good day. not even half of what i would give it.
Heres the simplest way to put it take the speaker out the box go to bcae1.com go down the right side of the page and click number 38series/parallel basics read it over unti you get it then see if its wired in series or parellel if you stll dont get it pm me and give me a call I can explain a little more to help out
That amp will actually do 120w at 8ohms bridged (60w per channel at 4 ohms)
yup, that's series wiring so 4ohms. Easy way to remember is a dvc can either be 2x the rating of each coil (wired in series, so in a line) or 1/2 wired in parralel (wired separately). It make sense when you think about it that way, at least for me it did.
Heres the simplest way to put it take the speaker out the box go to bcae1.com go down the right side of the page and click number 38series/parallel basics read it over untl you get it then see if its wired in series or parellel if you stll dont get it pm me and give me a call I can explain a little more to help out
Very simple pull the sub and look at the wires.If both positive and both negative wires are bridged to the box connector it is in parallel or 2 ohm
thanks, but see my above post. I took it out of the box and it's a 2 Ohm rather than 4 ohm and it's wired in series....making it 4 ohm load? Does that mean i can get a good 150w RMS from my amp if i wire it in bridged at 4 ohm?
gravityeyelids
Mich
bbeljefe
maylar
    Jun 2, 2024
    Jun 1, 2024
