Dual 15" SP4 Silverado SS Build
Interested to see this 3rd seat design. I wanted to go big but im almost always 3 deep.
The seat will be about 18" wide which isn't too small its just a seat to hold the 12 pack or some one needing a ride. I will meter it in the back seat for shits and giggle, your head would be like 8" from the port.
Or you could just text me. But alright. Pics will be posted tomorrow, send money and they will be shipped accordingly.
Thanks....
You respond faster on here and said you tried contacting me and I didn't get **** so I thought your phone was messing up again.. That's why its on here and again ive had money ready since 1999 just need real pics to see what I'm getting
Can't wait to see the Exodus Anarchys. Give him time, they need to be build right.
What's the plans are you going to wrap them? paint them?
I haven't decided what finish I'm doing yet, they will match my box. Any ideas?
Here you go. Pics of the driver, ill take pics of the passenger if you want but it sits just as flush and looks the same. Up to you. Here they are none the less.like I said earlier, the most factory appearance would be to black or dark grey vinyl wrap them.
Yeah you can see through several mounting holes so there is definitely some space between there. I suppose all that matters is that the rearwave is completely sealed into the pod/door. I suppose in the end if sealed up properly it is solely aesthetics, making things look not so great. Perhaps he's got something planned for that //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
That pic right there you can clearly see the 11, 9, and 7 o'clock holes on the speaker on the left are past the ring the ring you made should come to the outer edge flush with outer edge of speaker. For a super clean look. And the holes at the 1, 3 , and 5 o'clock on the right speaker are the same way.
exactly why you pay half first up front as down payment then go from there //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
535
701
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
935
Silverado SS
Shake Pound and Rattle
Silverado SS
Cleveland
gckless
Decebal
    Jun 10, 2024
