Dual sub box only playing one sub
  • 5
PNILLZ
My sub box only plays one sub when I connect them both the amp will go into protect mode. I checked all the connections they were fine, and my left sub plays fine. When I connect the right one by itself, it doesn't play is it blown? Is it time for a new setup? I've had this one for about 2.5 years
If you know what Coil configuration your subs are, you can disconnect from the source/amp, and use a DMM to check the coils,to find out if its blown or not.Very easy to do.You can YOU TUBE it up, and watch a tutorial on how to do it,easier than explaining it to you
I would check the impedance on all of your voice coils to make sure you don't have one out. That would give you a whacky impedance and could cause the amp to go into protect. Otherwise you may just have a badly blown woofer that when connected is sending a dead short to ground to the amp which will absolutely freak it out.
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
852
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
I would use a single chamber and a single port, if you can. Single chambers and a single port will usually lessen chances of cancellation...
618
PNILLZ
PNILLZ
New Jersey
UsAmpsFreak
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
