Dual xpa4640 wiring from 2 rca from head unit into a single sub
  • 1
DethRattle
CarAudio.com Newbie
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the amp. I just have 2 rca's coming out the head unit ran to the trunk right now and want to use this amp to power one sub. Please help i'd appreciate it.
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
770
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
787
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
887
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
DethRattle
CarAudio.com Newbie
DethRattle
Adrian, Michigan
DethRattle
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
