Sub replacement dual vc to single vc- Toyota sequoia
  • 2
Tusa123
CarAudio.com Newbie
Hoping someone can help. I’m not finding anything on the web.
I’ve heard a few positive comments about simply replacing the 8” factory sub with an aftermarket sub. Crutchfield sold me a svc sub but when I pulled the factory sub out it was a dvc. Two sets of wires coming from the factory amp to the sub.
That said, how do I wire a svc sub in the place of a dvc sub? 4 factory wires vs 2. I should clarify that each terminal on the factory dvc measures at around 1.7ohms. The new svc sub is 4 ohms. The truck is a 2015 sequoia with Jbl. Thanks in advance.
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
If you still have the old speakers, put them in and see what happens.
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
235
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
382
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
479
Tusa123
CarAudio.com Newbie
Tusa123
Seattle WA
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
