EQ power question
  • 4
Yes it'll work. No matter what HU you have at it's lowest volume setting it will be putting out less then 1v, as you turn the volume up the voltage will go up. That 2v-6v is probably where there item works best.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
8
opethfan
opethfan
western ny
opethfan
