ext cab ranger with a little power
im also going to make some pods to put the Rainbows in since i dont want to cut the doors.
there are kicker 5x7s in front and rear right now. dont sound all that bad but they wont be used for much longer
wanna pass a pair my way //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif, I need to find some cheapo's to put in my temp truck when I give it back to my grandfather.
if i pull them out we can work something out. im not planning on getting rid of the truck anytime soon that and im not a huge fan of kicker.
im thinking since everything is pretty simple so far that i may pick up some diamond plate tomorrow and weld up some battery boxes. well more like covers.
what do you guys think? to much or would it look good
everything in and sounds good. lows are still there even with being 8s. the bass is very crisp
weather got bad so have to wait to fine tune tomorrow hopefully.
right now the subs are seeing about 2000 watts while i break them in.
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
bones22
bones22
in my house
poundindak69
