Extended Cab Silverado bench seat conversion
  • 4
Hey guys im looking at building a custom center console from the front all the way to the back wall of my 2004 Extended Cab Silverado. I am wondering if anybody has had any luck cutting out the center portion of the bench seat and welding bars to keep the door seats?? I am looking at price and the easiest way to do it. I know i will have to reupholster the seats. But im trying to figure out how to cut the seat or who to look for that could maybe do something like this. Thanks!
I'm going to be helping a friend with his truck when it warms up. We're removing the back seat in his extended cab Silverado. Where the seat was, we're building a box for the subs. The subs and port will be facing forwards, and the top of the box will be cushioned upholstered so people can sit on the box like it was the seat. Basically we'll just be getting more box volume compared to an under-seat box.
I say just try that, and forget about cutting the seat.
ive already had this done on a 00 so let me know if you want some pics or tips on how it was done
i seen a youtube vid were somebody did this. they did not have to reupholster it. if your were closer i would do it for ya..
as i weld..
ill look for the vid.
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
adamp5460
adamp5460
Russellville, AR
adulbrich
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
