Extra Power
  • 5
RDSHunter
I've heard of many subs being stable past their reccommended RMS wattage and wonder how much of a difference is actually made. Ive got two JL 12w3v3 subs with a Cadence ZRS 7000D amp and Was wondering if I wired it down to 1 ohm (pushing 650 RMS to each sub rather than the reccommended 500 RMS) how damaging this would be to the subs or if there would be a significant enough increase in sound. I figure the gains and sub levels on my HU would have to be kept low to run smoothly at extra power. Since I've heard of it being done I figured I'd ask before I went on and ended up blowing my subs haha. Thanks
they will go up in smoke i know from personal experience
there peak handling is 500....unless you plan to burst this power?
There peak is 600 to be exact.. As far as how much power they can hold well there is only one real way to find out but it might end up costing u some money lol. I would say a good clean 800 to the pair would be about all I would mess with. Also depends on what kinda box u are using..
FWIW 'peak' numbers are useless //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
and it's THEIR
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
485
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
709
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
518
RDSHunter
RDSHunter
Detroit, MI
THATpurpleKUSH
maylar
    Jun 2, 2024
    Jun 1, 2024
