SOLD ***F/S A few things that need to go amps, subs, speakers, PAC, etc. F/S***
oxsign
No Affiliation
6,046
34
Orlando, FL
First I have a pair of Infinity Reference 3 way 6x9's $60 shipped to the lower 48. Sorry for the dust. They were in my blazer for 1 full day till I sold it.
Next up is a pair of Polk Audio 4x6 plates BNIB never installed or taken out of the packages. MMC460 $60 shipped to the lower 48.
Next is a PAC SWI-PS. This alows you to use you factory steering controls with an after market deck. This is used for a Pioneer and/or Sony decks only. $20 shipped to the lower 48.
Next up
Kenwood KAC-628 Car Audio Amplifier. It's a little beat up, but works flawlessy. $40 shipped to the lower 48.
Key Features
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 50 W x 2
RMS Power at 2 Ohms 75 W x 2
Performance
Frequency Response 10 Hz - 45000 Hz
Signal to Noise Ratio 100 dB
THD at Rated RMS Power 0.08 %
Other Features
Input Voltage 14.4 volt
MOSFET Circuitry Yes
3 Way Ready Yes
Dimensions
Width 8.69 in.
Depth 9 in.
Height 2.19 in.
Next is a Power Acoustik PS4-240 4ch amp. $40 shipped to the lower 48.
240 watt 4 channel car amp
45 x 4 @ 2 ohms RMS rated with true world ratings
Full MOSFET power supply
PWM circuitry
Selectable crossover (High/Full/Low)
Short , thermal, and overload protection
tri-mode capable
2 ohm stable stereo
Variable low pass: 40 Hz–120 Hz
Variable high pass: 150 Hz–1.5 kHz
18 dB bass boost @ 40 Hz
Freq resp: 10 Hz–30 kHz
S/N Ratio: 97 db
THD: 0.02%
System Distress indicator
High/low level inputswith floating ground
4-gauge power/ground connection
Gold-plated RCA connectors
Line output
4? RMS: 35 x 4
Dim: 9"H x 7"W x 2"D
Next is a pair of old school Kenwood KFC-W2502 10"subs. These things are rough, but work & sound great. One has a small hole in it (**** drill), but it does not effect the performance or sound. $30 for the pair shipped to the lower 48.
Next is a pair of SQ batt. terminals. Never used or connected/mounted. They will accept a 1/0, 4awg, & 2 8awg connections. $10 shipped to the lower 48.
And last I have a brand new never used wire harness for a Sony CDXF7700. $5 shipped to the lower 48. Pix of that will be up later.
All prices are O.B.O., so let me know what you want, and what your offer is by PM's, or post here. //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
331
oxsign
No Affiliation
oxsign
Orlando, FL
brchd
Decebal
    Jun 10, 2024
