F150 Crew Cab Help
  • 1
awood0909
I am just starting to replace factory items in my 13 f150 crew cab. I have decided to go only replace the front speaker and add a sub under the back seat. I have the touch screen head unit and don't know if I need to run an amp to the front speakers. I want to install some components that will run me about $150. As far as the sub goes, does anyone have a recommendation for the thinner subs out now? I will be building my own box as budget is important in this build. Any help appreciated.
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
6
They really are. Fit to perfection! Sounds Good Stereo are the best.
7
awood0909
awood0909
oklahoma
awood0909
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
