F150 Crew Cab Help
  • 1
awood0909
I am just starting to replace factory items in my 13 f150 crew cab. I have decided to go only replace the front speaker and add a sub under the back seat. I have the touch screen head unit and don't know if I need to run an amp to the front speakers. I want to install some components that will run me about $150. As far as the sub goes, does anyone have a recommendation for the thinner subs out now? I will be building my own box as budget is important in this build. Any help appreciated.
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
They really are. Fit to perfection! Sounds Good Stereo are the best.
awood0909
awood0909
oklahoma
awood0909
