factory amp bypass
  • 2
Mongojerry36
i know this question mustve been answered before but I have a 2001 toyota avalon with the JBL system in it. I have subs in the trunk and im getting a double din headunit.
Im keeping the speakers stock and my question is do i need a amp bypass or can I just stick with the regular wiring harness without blowing out the stock speakers?
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
@1aespinoza I see, so this audio volume leveling is what I was experiencing tapping into the Bose sub wires. Well then, I'm off to check out the...
4
Mongojerry36
Mongojerry36
New Jersey
Mongojerry36
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
