Fiberglass enclosure vs door install
  • 3
PepsiFiend69
I have an 08 f150 and am trying to weigh my options on front door speakers. It has an odd design where the speaker bolts through the front door panel leaving a big open space around the speaker. I'm looking for good midbass output. I could either fiberglass a small inclosure and integrate it into the door panel, or use the standard location and spend the extra money on sound deadening the whole door. I'm doing a budget setup and will be using probably NVX 6.5" coaxials amplified. What would be my best bet for what I'm looking for?
A "small" enclosure is the last thing you want for almost all 6.5" speakers when you need midbass. Playing into the cavity of the door is the expected installation. The door needs to be changed to a more appropriate enclosure. It will never be sealed, but there are several treatments available that make a massive improvement.
For inspiration: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/627952-2002-toyota-camry-khas-wife-gets-system.html
Thanks! I'll take a look through.. I've been out of the audio game for 8-9 years. Looking to get back into it since my commute just tripled and I spend way more time on the road. A little rusty on my knowledge on everything so trying to brush up and re-learn some thing and play around with some ideas.
My goal is to get a nice sounding budget front stage and maybe add a small sub later on. Earlier in my life I was much more into getting loud, my goal with this is budget and good sound. And I know install is everything, so pardon my probably stupid sounding questions.
That is an awesome thread. Lots of ideas I will be stealing for the refresh of my own install. Love the crossovers under the seats. Using a single piece of wrapped plywood for the amp mounting looks like a way better idea than what I had planned...which was two pieces of cut, carpet wrapped MDF.
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
702
PepsiFiend69
PepsiFiend69
Pottstown, Pa
Water Bear
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
