fiberglass!?
depends on the aplication....generally if your going to have a large area thats what you do.....alot of people will just use the mdf rings and apply fleece to it to create a form then apply mat and cloth to the underside of it for strength
Originally posted by Corsica Well fiberglass maynot be as hard as they make it out to be then. Can anyone tell me where thye learned how to glass?
J
I learned by rebuilding jet ski hulls. I watched the first couple of times, then started playing with it. Before you know it, I had built my first Hull. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by shrinkydinx for a fiber glass box, do you build the square parts out of mdf? and then the curvy parts is where the fiberglass comes into play?
Yeah man. That's the easiest way there is. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by fisherpricekid i am new to the fiber glass ways what do u mean by matt? liek is that extra thick fiberglass? and how many layers of glass do u use?
The answers to all of your questions and many more lie within my child //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
http://www.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=32;t=000549
Don't stay up to late reading //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Enjoy
Hey Just a little hint on help from when I built my box......for the rings where you will screw your sub down line it with dynamat and cut through the mat to fit the sub works wonderful!
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
fisherpricekid
fisherpricekid
sherwood park, AB
Mr. Loki
    May 16, 2024
    May 16, 2024
