FS: Cactus Sounds K9S
  • 5
AudioAnonymous
Item:
One Cactus Sounds K9S
Specifications:
Model K9s
4 Ohm Power: 2750W
2 Ohm Power: 5100W
1 Ohm Power: 9300W
1 Ohm Power 16V: 11000W
1 Ohm Power 18V: na
Freq Response: 20-250Hz
Signal to Noise Ratio: 95dB
Damping Factor: 250
Input Sensitivity: 6V - 0.2V
Low Pass Filter: 35-250Hz
Subsonic Filter: 10-50Hz
Bass Boost: 0-9dB
Master/Slave Connections Linked to 2 Ohms, Thick 3oz Copper Traces, 3 x 0awg Connections, 54.59lbs
Heavy Duty Aluminum Heatsink
Oversized Power Terminals
24dB/Octave crossover
3oz Copper PCB to Support High Current Flow
Utmost Stability for Daily Driving
Oversized 0 Gauge Power & Ground Terminals
2.5mm Thick Copper Traces
Description/Condition:
Used but not much. There's some marks where you put the screws in to mount it down but that's normal wear and tear. To be honest I haven't looked at it super close but I would give it a 9.0/10 for cosmetics and 10.0/10.0 for performance.
These amps are known to put out more power than rated and at a lower voltage than tested at.
1600 shipped/insured, or 1500 picked up
//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
O man...If I only had the money =[[[
this should sell fast!!!! glws!
hmmm, I was going to spend some money on front stage for daily driver but this makes me want to buy it, and go buy a vehicle specifically for the amp lol.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
610
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
AudioAnonymous
AudioAnonymous
Green Bay, Wi
8thGenSI
    May 24, 2024
    May 23, 2024
