FS: Linear Power 3.2 HV & DPSQ50 Amps
  • 2
Mully
Linear Power 3.2 HV:
RMS Power Output (4 Ohm Stereo/4 Ohm Brgd) @ 12.5 volts: 200 x 2/700 x 1
RMS Power Output (4 ohm stereo/4 Ohm Brgd) @ 14.4 volts: 280 x 2/875 x 1
Maximum Peak Output (Mono): 2100 Watts
THD @ full output 20 - 20Khz: .008%
Dimensions: 3" x 9.5" x 14.5"
Linear Power DPSQ50:
4 CHANNEL AMPLIFIER
WITH ELECTRONIC VARIABLE CROSSOVER
Features include; Built-in adjustable crossover networks offering 12dB of slope, switchable to high-pass, low-pass, band-pass, or full range. A line out has been provided to allow for expansion of your system which also features an adjustable crossover range of high-pass, low-pass, or full range. Gold plated 5 way speaker binding posts allow for ease of connection.
RMS Power 4 Ohm: 40 x 4
@ 12.5 V dc: 125 x 2
RMS Power 4 Ohm: 50 x 4
@ 14.4 V dc: 165x 2
RMS Power w/ 60 x 4
Music (4 Ohm) 200 x 2
Dimensions: 2.8"x9.0"x11.0"
I am the original owner and have original box and manuals. Both are in excellent working and cosmetic condition.
3.2 HV: $800
DPSQ50: $500
Included
Mully06-20-2014.jpg'%20alt='Mully06-20-2014.jpg'>
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
277
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
592
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
435
Mully
Mully
Paris, Il
soccerguru607
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
