SOLD FS: Rockford Fosgate FNX2414 4" Component Speaker System!
  • 2
kyle454ss
NOR CAL
I have a new RF FNX2414 4" Component Speaker System, $100+$10 shipping.
Specs:
Information about Rockford Fosgate FNX2414 Car Component System
Product Information
4" 2-way Component set. Contains 2 Woofers and 2 Tweeters. Woofer cone: Poly/Plastic, Injection molded titanium plated polypropylene. 1" multilayered copper Woofer voice coil. Rubber woofer surround. 0.75" Tweeter, silk soft dome. Power handling 70W RMS, 140W Peak.
Product MPN
MPN fnx2414rf
Key Features
Car Speaker Type Component System
Elements 2-Way
Car Speaker Function Subwoofer, Tweeter
Size 4.00"
Nominal Power Handling 70 Watt RMS
Powered Non-Powered
Technical Features
Peak Power Handling 140 Watt
Frequency Response 50 Hz - 20 kHz
Impedance 4 ohm (Dual Coil)
Components
Tweeter Design Dome
Tweeter Size 0.75"
Woofer Material Metal
Surround Material Rubber
Mounting
Enclosure Non-Enclosed
Top Mounting Depth 1.75 In.
PM if interested...
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
kyle454ss
kyle454ss
NOR CAL
kyle454ss
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
