SOLD FS: Rockford Fosgate T3002 CHEAP
gboo559
^^$1 Car Audio Decals^^
Rockford Fosgate T3002 Class A/B...one of the most UNDER RATED amps ever
10/10 mechanically
9.5/10 cosmetically only cause it has a small scratch on the bottom...nothing a lil paint can't fix up
Specs:
Amplifier Type: 2-channel
12dB or 24dB/octave selectable crossover
2/4 channel switch
4 Gauge Power/Ground connections with built-in ATC fusing
Audiophile grade amphanol speaker connections
Best in class 4 oz. copper traces
MasterSync
PowerSync
Stealth Connections
50 W x 2 @ 4 Ohms RMS
100 W x 2 @ 2 Ohms RMS
150 W x 2 @ 1 Ohms RMS
200 W x 1 @ 4 Ohms bridged RMS
300 W x 1 @ 2 Ohms bridged RMS
I remember the birthsheet saying it did a little more than 850 x 1 @ 2 ohms bridged.
$150 SHIPPED/INSURED OBO to the lower 48. This goes for $220 new and I haven't even hooked it up yet.
Cheaper if you're local or in Cali.
this particular RF Power Series is the most underated model i have ever known RF to make
it is rated at 300 x 2
this amp is more like 1000 watts
buy this guys amp
buy this guys amp
Thanks man. Yea I've seen one on a RF forum that did like 927 rms. 3X more than rated! Also forgot to mention it's a Class A/B amp.
The box I build for a Rockford fosgate T1 12" a few months back, the guy has a dual 2 ohm, running on this amp I sold him.
Has been running @ 1 ohm bridged everyday and he has never had a problem. The gain is pretty low though as I imagine @ 1 ohm bridged it's doing over 1kw
Great little thing
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
gboo559
gboo559
Central Cali
gboo559
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
