Fusing question
  • 4
Why So Cereal?
Invisible Cereal
Right now i have zero gauge going from hood battery to batcap 800 in trunk. the wire in hood is fused with a 300a fuse.
I plan on running a kicker zx1500.1 that calls for 150a of fusing. Do i need extra fusing in the trunk? or should i be fine with the 300a fuse in the hood?
In any direction. IE - that 0ga run to the rear battery should have a fuse before it gets to the rear battery. If not, then if something happens to the cable under the hood (after the front fuse), then you have a 0ga line being fed by the rear battery towards the front. Fire. Fire! Fire!! Yuck.
So two batteries = three fuses!
front battery - fuse - 0ga run - fuse - rear battery - fuse - amplifier(s)
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
413
768
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
mikelaubach
