Fusing question
  • 4
Why So Cereal?
Invisible Cereal
Right now i have zero gauge going from hood battery to batcap 800 in trunk. the wire in hood is fused with a 300a fuse.
I plan on running a kicker zx1500.1 that calls for 150a of fusing. Do i need extra fusing in the trunk? or should i be fine with the 300a fuse in the hood?
In any direction. IE - that 0ga run to the rear battery should have a fuse before it gets to the rear battery. If not, then if something happens to the cable under the hood (after the front fuse), then you have a 0ga line being fed by the rear battery towards the front. Fire. Fire! Fire!! Yuck.
So two batteries = three fuses!
front battery - fuse - 0ga run - fuse - rear battery - fuse - amplifier(s)
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
537
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
827
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
mikelaubach
    May 18, 2024
    May 18, 2024
