General audio
  • 3
I pulled a pair of Tenna model C0615c 51/2 air suspension speakers out of a classic car I purchased. They look to be in great shape, are these worth keeping.
They are unique. I wonder if the 4 Ohms is for the main and 8 Ohms for the tweeter. I also wonder how they fit a 2 inches tweeter in front of a 5.25" cone. Add to that almost a pound of magnet for such a small low power speaker! Ve-ry unique indeed. This would fit well in a classic with shaft volume knobs.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
861
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
119
Tim B
CarAudio.com Newbie
Tim B
St Louis
spokey9
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
