general tuning question
  • 2
Jimg
CarAudio.com Regular
216
13
when setting speaker time alignment,
The center image is not in the center. It is still a little louder from the passenger side.
To correct this would you adjust the gain on the driver side speakers, or adjust the time alignment to shift the image?
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I didn't know you could even adjust that from left to right.
If your speakers are not angled and placed at the optimum location, I WOULD GUESS, you would be trying to make the DS louder. Can't you just do that with balance control? Never heard of gain adjustment controlling side to side. Gain adjustment is to amplify the signal.
Looks like it's wire it either 4 or 8 ohm 🤔
4
825
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
863
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
Jimg
Jimg
HardofWhoring
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
