good budget sub
itsblown
why is there smoke?
1,164
Toledo OH
the amp im going to be using is an audiopipe apsm 1500
So im just curious what you guys think I should run Ive got about 6 cubes of space to work with and a budget of about 200. My goal is mostly spl but I still want it to sound somewhat musical. Also im not against buying used soo let me know what you guys think
I have a brand new cadence beastmaster sub in original box. 15 inch d2. 1500rms was entirely built in the US with all US parts. it was a 699 dollar sub when released back in 04
here is a clip of a 18 doing 150
I will do it for 200 shipped, you wont find any quality sub like this for 200 bucks
again its brand new in its original box and has never seen power
i posted some links but maybe still not approved
anyway
sonic have 2 kicker comp 15" svc 8 ohm 250rms for $170 @4ohm your amp is 500wrms and will work
they also do 2 kicker cvr 15" for $260 but there dvc 4 ohm and wont suit you amp, but they have dvc2 if you ask
if i was on that tight of budget idd look at the 2 15 for $170, there not the loudest but will work/go loud in 6cuft
if you can stretch that budged to 300, look at Fi Bl 15 for $305 or 18 for $335
the fi would be my 1st choice
I was looking at the sa series actually it would just depend what size I wanted to go with you know. Im supposed to be going to look at some older memphis m3 dual 2's 2 10s for a hundo pretty **** good deal if there in shape but I gues will find out
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Higher preamp voltage is to reduce noise, but you generally don't get noise on the subwoofer channel.
4
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Looking for a pair of budget 8" subs to fill in the low end. They'll be going in a ~1cuft sealed enclosure (.5cuft/sub) under the rear seat of a...
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
970
itsblown
why is there smoke?
itsblown
Toledo OH
itsblown
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
