Good Wiring Kits?
jeffburgess10
Ohio
Hey everyone. I've been looking at wiring kits for the mono and 4 channel amplifiers I'm buying. I'll consider any price, but I'm mostly wanting the know what will be compatible for my system and what is the best bang for the buck.
Amplifiers:
Infinity Kappa four- 125 watts RMS
Infinity Kappa One 800watts RMS 1600watts peak
I plan on running all kappa speakers in this build with two Kappa 10's. Any suggestions would be much appreciated. And I plan on looking for someone on here to design me a custom box to if anyone is up for the task.. Pro Rabbit said he'd do it, but he bailed on me after we set everything up.
Thanks Everyone
I forgot to mention that I'm looking for 4 gauge power and ground kits that has everything I need to get my setup done.. Distributions blocks included. What I get confused on is the size of fuse i need and how much watts total the kit can handle. One of the amp needs a 80amp fuse and the other needs a 120 amp fuse. Will a 120 amp fuse work for both? This is my first build, and even though I've learned alot about setups I still have alot of things to learn.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
246
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
649
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
673
671
575
jeffburgess10
jeffburgess10
Ohio
jeffburgess10
Decebal
    Jun 10, 2024
