ground wire quick question
Ground wire should be AT LEAST same gauge as power wire and no more than 30" long. Period.
Deviate from those two simple rules, and you MAY encounter some problems.
It can be longer than 30 inches. Some people run their ground wire from the amp to the negative on the battery under the hood.
Why?
As long as it's sized correctly to account for voltage drop...would work fine. Isn't done as much for daily installs because using the vehicle as a ground is more economical.
I know it CAN be longer than 30", but you're asking for problems if it is. The owner's manual for every amp I've owned all state the same thing.
Some people are idiots too!
That is what alot of the big boys do. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Standard procedure for two-way radio installations as well...when it comes to RF frequencies, grounding through the frame is a sure way to pick up ignition noise and all sorts of nasties from the onboard computer(s).
What if I'm using 1/0ga wire for my ground wire, and my vehicle's chassis is equivalent to 4ga in resistence ?
How exactly did you come to determine 30" is the maximum length ?
What happens at 31" ?
The world comes to an end I guess. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I own 4 different brands of amps and all 4 manuals state to keep the ground wire as short as possible and always under 30". It's common sense really. The shortest wire in the largest gauge possible has the least resistance to ground.
I've always lived by these rules and have never had a problem. I never even dreamed of running an amp ground all the way back to the battery.
Not disagreeing that in general short ground wires are desirable and the shorter the better.
But there are many factors to take into consideration before you can determine what's appropriate and what's not.....and these factors aren't found simply by quoting an owner's manual //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
Thanks everyone, I connected the yellow wire from the sub to a blue wire on my pioneer head unit, which is for remote control apparently since it...
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
RollinRemz05
RollinRemz05
Toms River, NJ
DDFrontier
    May 18, 2024
    May 18, 2024
