Help design a box for re audio se-xv2 15s
  • 1
Cm_low
Vehicle : 2012 chevy cruze
Location in the vehicle: trunk
Space available (Length x Width x Height): 30 x 34 x 20
Subwoofer make and model: RE Audio se-xv2
Subwoofer Size: 15
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): slot
What type of music do you like?: slow n throw, decaf, rap, dubstep, drum n bass
Is your goal SPL or Everyday Music?: SQL sound good and be loud
Tuning Freq (Hz): manufacturer recommends 34hz, sonicelectronix recommends 40hz
Volume : manufacturer recommends optimal ported 4 cuft per sub
Questions:
I am not sure what to tune the box to. I like and listen to most music in the 20-40hz range ( alot of slow n throw ). A review said that he tuned to 28hz and they were not loud at all so he retuned to 34hz and said huge improvement. Currently I have them in a 2 cuft sealed after displacement box and they get real loud now but I haven't had to worry about tuning yet. On the current sealed box the under 30hz range is lacking compared to other subs I've owned previously. So I am open for tuning suggestions but more than likely it looks like 34 hz recommendation from manufacturer sounds like the best.
Never built my own enclosure yet so not sure how to design it to get correct measurements of everything with proper port size and tuning.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
713
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
12
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
5
981
Cm_low
Cm_low
Arnold, MO
Cm_low
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
