Help installing amp in new 2013 accord
  • 2
Jaxxx
Usa
Looking to run an amp in the rink but can't figure out where to run the power wire through the firewall and where to hook up the remote wire.
I didn't see anything on the firewall from looking with a flashlight and it has a touch screen radio which is not like any other aftermarket radios I've worked with years ago.
There is a easy way through the firewall it is located to the left of the driver foot rest you will see three grommets remove one and feed wire thru. From there if you open the hood and look to the location of your wipers on the drivers side there is a piece of rubber that can be lifted up which gives you access to pull the wire thru and into the engine compartment. you can use a hanger to pull wire through.
Let me clarify I meant remote wire on my original post....... I will look through the footrest tonight for the power wire.
I'm not sure that's why I ran the dsp first so I could level it all out. Some do have the factory mine didnt
8
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
170
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
505
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
371
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
356
Jaxxx
Jaxxx
Usa
Jaxxx
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
