Help me pick a single 12" sub for SQ and depth
  • 6
mrmex
colorado
Hi, i've decided i want something better than i have now. Used to have two twelve JL's and now a single old mtx 10. Reason being is my rig has limited space for amps and subs. What i plan on doing is building a custom box in the back.
Requirements:
The box has a max depth of about 4-5". With this depth allowed i doubt i will find any good 10-12" out there so two 6 or 8" subs would be optional.
Also is ported or sealed better?
The amp i am using will be 300 rms output (not changing it)
max $200
Loud and clean as possible
Thanks!
I have a brand new JL W3v2 that's super efficient and would do great on that amp for a very negotiable price. Definitely in your budget. Shoot me a PM if you are interested.
What amp?Model and Brand.What vehicle?Location of where sub will be placed inside vehicle. Dimensions of enclosure,and tuned too,and size of wood used(5/8,3/4 ect.,prefabed,custom built)?
What amp?
What vehicle?
pioneer prs- d4200f
1994 land cruiser
rear quarter panel
all this is something i can build to suit for the sub, only depth would be the limiting factor. I do already have 5/8 mdf ill be using
CT Sounds Tropo 8 v1 is 4.72" mounting depth, 250 wrms, comes in D2 or 4 coils and two of them can be had for less than your budget.
EDIT: And I would recommend running a ported enclosure even if that means running only one sub. :)
I can't find any of the subs you guys have recommended. What about this, it looks like a great deal to me as there are some blemished ones for $130 shipped.
Sundown Audio SD-2 10" 500 Watt SD Series Subwoofer - 1800woofers.com
The box size mounting depth and price is perfect.
Its a little high on the wrms but 300 should still feed it alright?
Or should i go with the 8" as it is 300wrms and would leave some wiggle room if i can't the box big enough. Just wondering how much sound i will be losing over the 10"?
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
203
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
615
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
400
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
375
mrmex
mrmex
colorado
mrmex
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
