help me tuning my sound system
  • 2
irshad
CarAudio.com Newbie
hi
i am new here and i need your help to tune my sound system.
here in my country there no technicians or even enthusiasts able to tune my system.
i have at the moment the following components:
HEADUNIT specs:
alpine cde193bt  6 channel
Sound Tuning
Subwoofer Level Adjustment: 0 to 15 dB
Subwoofer Phase Setting: 0° or 180°
BASS ENGINE SQ: Level 0 - 6
Bass Level Control Range: ±9.1 dB at 100Hz
Treble Level Control Range: ±9.1 dB at 10 kHz
Parametric Equalizer (Band 1): 20 - 100 Hz
Parametric Equalizer (Band 2): 63 - 315 Hz
Parametric Equalizer (Band 3): 125 - 500 Hz
Parametric Equalizer (Band 4): 250 - 1k Hz
Parametric Equalizer (Band 5): 500 - 2k Hz
Parametric Equalizer (Band 6): 1k - 4k Hz
Parametric Equalizer (Band 7): 2k - 7.2k Hz
Parametric Equalizer (Band 8): 5.8k - 12k Hz
Parametric Equalizer (Band 9): 9k - 20k Hz
Parametric Equalizer (Gain): -7 to 0 +7
Parametric Equalizer (Bandwidth): 3, 4, 5
2Way Crossove Mode: Cut-off Frequency 20-200Hz, Slope Flat/6/12/18/24 dB/oct, Level -12 to 0dB
3Way Crossover Mode: Cut-off Frequency Low/Mid Low 20-800Hz Mid High 20-20kHz High 1k-20kHz, Slope Flat/6/12/18/24 dB/oct, Level -12 to 0dB
Application Volume Level Setting: ±14 dB
AMP specs:
Pioneer gm-d9605
•5 Channel Champion Series Class D Amplifier
•Max Power Rating:
?4 ohms: 150 watts x 4 chan. + 700 watts x 1 chan.
?2 ohms: 200 watts x 4 chan. + 1200 watts x 1 chan.
?Bridged, 4 ohms: 400 watts x 2 chan.
•RMS Power Rating:
?4 ohms: 75 watts x 4 chan. + 350 watts x 1 chan.
?2 ohms: 100 watts x 4 chan. + 600 watts x 1 chan.
?Bridged, 4 ohms: 200 watts x 2 chan.
•Total power output: 2000 watts Max
•CEA-2006 Compliant Amplifier
•Pulse Width Modulated MOSFET power supply
•Wired remote bass boost level control included
•LED power (green) and protect (red) indicators
•Soft start turn-on
•Speaker-level (high-level) inputs
•5, 4 or 3 channel operation
•Dedicated, large-block subwoofer terminal output
•Nickle-plated RCA, Speaker and Power/Ground Terminals
•Selectable input modes:
?Front two channels (RCA Only) can provide signal to remaining channels
?Four channel High-Level connection can provide signal to Subwoofer channel
•3-way protection circuitry (thermal, overload, and speaker short protection)
•Heavy duty aluminum alloy heat-sink for extreme heat dissipation
•Input sensitivity:
?Low level: 200mV - 6.5V
?High level: 800mV - 16V
•A/B Channel Frequency Response: 10 - 50,000 Hz (+0dB, -3dB)
•Sub-Channel Frequency Response: 10 - 500 Hz (+0dB, -3dB)
•Total Harmonic Distortion (THD): 0.05%
•Signal to Noise Ration: 94 dB
•Selectable crossover filter (Ch 1 - 4): LPF / OFF / HPF
•Variable crossover filter (Ch 1 - 4): 40 - 500 Hz, 12 dB/octave
•Variable low-pass filter (Sub): 40 - 500 Hz, 24 or 12 dB/octave
•Variable Bass Boost (Via Remote): 0 to +18 dB bass boost at 50 Hz
•Fuse Rating: 30A x 3
•8 - 16 Gauge speaker terminal outputs
front splits system
kicker css65
General Features:
6.5" Two-Way Component System
Power Handling:
Peak: 600 watts per set / 300 watts each side
RMS: 200 watts per set / 100 watts each side
Polypropylene cone
UV-treated, ribbed midwoofer surround
3/4" Titanium dome tweeter
4 ohms impedance
Frequency Response: 35-21,000 Hz
Bottom-mount Depth: 1-11/16"
Tweeter flush-mount depth: 9/16"
Sensitivity: 90dB
High frequency output attenuation: 0, 3, 6
High Pass, dB at frequency: 12, 4,000
Low Pass, dB at frequency: 12, 4,000
Midwoofer grilles included
rear coaxials
kicker csc65
General Features:
6-1/2" CS Series 2-Way Coaxial Speakers
Power Handling:
Peak: 600 watts per pair / 300 watts each
RMS: 200 watts per pair / 100 watts each
Recommended Power Range: 10 - 100 watts RMS per channel
Features EVC (Extended Voice Coil) technology - immediate improvement above OEM
Polypropylene mid-woofer cone material
Polyester foam speaker surround
1/2" Polyether imide (PEI) balanced dome tweeter
Neodymium magnet motor structure
Stamped steel frame basket
Top-mount Depth: 1-11/16"
Cutout Dimensions: 4-13/16"
4 ohms impedance
Frequency Response: 40 - 20,000 Hz
Sensitivity: 90dB
subwoofer
rockford p2d215
15" subwoofer with dual 2-ohm voice coils
molded polypropylene woofer cone with poly-foam surround
"Venturi-effect" design for maximum cooling of motor structure
power range: 50-250 watts RMS (500 watts peak power)
frequency response: 20-250 Hz
sensitivity: 86 dB
top-mount depth: 7-1/8"
sealed box volume: 1.3-3.5 cubic feet
ported box volume: 2.66 cubic feet
warranty: 1 year
the amp is connected to headunit with a stinger cable :
Stinger SI4612 Audio RCA Interconnect Cable 6 Channels 4000 Series 12 ft Stereo
i like bass and not too much treble.
my car is a small hatchback (smaller than golf and bigger than yaris). the tweeters are mounted on doors near A-pillars.
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
I may have missed it, but do you have sound deadener on the doors? If not that could be why you're lacking midbass.
817
Do you intend to drive around playing test tones? If your intention is to play music, you should be using music you intend to play to dial in...
9
irshad
CarAudio.com Newbie
irshad
nauc
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
