Help picking speakers.
  • 2
steele6794
Boston
I've decided to put mids in my kickpanels. Behind the kicks there is a space that measures 9" Wide x 16" Tall x 4.5" Deep. The space is mostly sealed and I will try to seal it completely, so I believe it is a good location to mount mids and I know install is extremely important so proper preparation will be done.
I'm probably going to do a 2 way plus sub. I have the popular 6.5" SB acoustic 17MFC mids in my truck and would like an upgrade over those for this project. I will be feeding them with a ppi 900.4 or buy another amp if more powerful speakers are recommended. I will be running them active using either a pioneer 80PRS or my JL twk DSP. My budget is $300-350 but less is preferred especially if performance is similar for a lot less. I'm also going to need tweeter suggestions if you want to throw some my way to match with your mid suggestions.
I know the difference between speaker performance for any given price range is negligible so I'm just looking to be pointed in the right direction for a group of speakers that will give good midbass and play loud and clear...Doesn't everyone...
Sub will probably be a single ported Icon 12 to start then 2 Icon 12's. I've always wanted to try those
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
6
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
steele6794
steele6794
Boston
huberoy123
