HELP! Speakers stopped working after steering column fix!
  • 2
I have a JVC KD-X330BTS after market stero.
I drive a 2001 Pontiac Grand Prix GT.
A while ago, I was able to turn over the ignition without any key and my battery would die every night. To fix this I brought it into a local shop to get it fixed. They fixed the steering column, AC/HEAT and gave me a new set of keys and a FOB. When I went to go pick the car up I was checking to see if everything was working correctly. But alas, my speakers did not work. I was unsure of the cause because they worked perfectly fine before...
My stereo lights up and everything and I am able to change settings and such.
I've checked RADIO, RADIO AMP, and Stereo fuses which all are intact.
I've also reset the stereo but still to no avail...
I am unsure as to why this happened. Does the steering column have anything to do with the stereo or speakers? Please help.
No.
I needed the heating for the conditions where I live. Temps go from -30C or -22F. It was much needed.
I could not lock my doors either, and I my car could be turned on without a key. FYI it was much needed.
Your reply still doesn't answer my question...
You weren't specific enough in the 1st post, and assumed they did some un-needed work.
I'm guessing someone was messing with the wrong wires underneath the steering column. Why not go back and make them fix it?
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
Hey, I have golf 2019. I have audison voce and want another speakers in front, and the Audison move to the back I have thought about those- Focal...
ChillehSweets
ChillehSweets
Brooks, Alberta
Boomin_tahoe
    May 31, 2024
    May 24, 2024
