Help with Sub vs amp wattage
  • 3
bassinmytruck
Can someone please give some insight into my first truck subwoofer purchase. I am looking into putting a kicker comp 10" with a ported enclosure into my 1999 Ford F150. I wanted a sub that i didnt have to upgrade my alternator or battery for. I happened to stumble apon a ebay link.
Kicker Car Audio C10 Comp 300W Loaded 10" Ported Sub Box Boss CE202 Amp Package | eBay
It seemed to have everything i needed to build my system. I looked into it further thou and didnt understand why this was all bundled together. The speaker is a 150 rms kicker 10" with a svc. The amp was a boss 2 channel that could be bridged at 500w for 4 ohms. This made no sense to me, how could a 500 watt amp be paired with a 150w sub? Any input would be greatly appreciated!
Well it is a boss amp so you probably won't see anything near the wattage it is claiming. Just make sure your amps gain is set properly. It is not a volume knob. If you ever decide you want something louder than that I would suggest asking around for help on here rather than buying pre made packages like that. It is okay for a beginner but if you spend some extra time learning about it all you could build something that will get a lot louder than that and sound nicer for not too much money. If you have any questions feel free to pm me.
DimwitRe: Help with Sub vs amp wattage
Thank you for your input! I have considered building my own system but have been having trouble finding much for under $200. I have hear good things about the kicker subs and dont have much room for anything bigger than a 10". Any other suggestions for an amp that goes with a kicker comp 10"?
If I remember right ppi makes pretty good budget amps and hifonics amps will be better for you than a boss amp. I know knukonceptz makes good and cheap amp wiring kits. If I were you I would look into the soundqubed subs. They are supposed to do pretty well and don't cost all that much. The HDS210 is only $79
That amplifier will not produce 500 watts. That is the peak power rating and it means nothing. It's also not likely that it will do its RMS rating of 125 watts per channel so the most you could expect from it bridged would be ~175-200 watts, which is not too much power for a 150 watt RMS sub. In addition to that, the wiring kit that comes with that bundle is undersized and won't be of much use if you ever get ready to upgrade your system and the sub is an entry level sub that won't do much other than be loud.
I understand that budget is a concern but I also understand the "bass bug" and I would hate to see you buy this setup, catch the bass bug and then find out that not one thing you bought could realistically be used in a more powerful and better sounding setup. That said, if you think you'll be happy with this entry level setup, then by all means get it. But if you think you may want more down the line, you'd be well served to save and buy one piece at a time until you have an expandable and dependable entry level system.
You can even find some really nice, high quality used gear here from time to time.
^ What he said.
And to follow up on my other post the PPI BK650.1D would be enough power for the HS210 if you were going to go with that and could be had for around $115. With an amp wiring kit from knukonceptz I think that would put you at about 215. How much space are you working with?
Thanks again. But assuming i have a 60 amp alternator, and around half of it is going to the battery, wont 600 w be too much to be self sustaining? They do look like amazing subs tho, dvc will also be nice for a 2 channel amp.
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
3K
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
bassinmytruck
bassinmytruck
Wichita, KS
bassinmytruck
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
