Honda Wheel Bearing ?
infamous_e46
hArRy_DaNgLeRs
26,366
California
This b!tch hums at speeds over 40 sounds like its coming from the right rear
i jacked it up tonight at work during break and tried wiggling the rear wheels
and they have no play in them so i removed the wheels and drums and spun the hubs
no grinding or wiggling
wtf broz
look at that beast 35+mpg
when it starts to hum, does it go away when you make a turn in either direction? if it does than it's most definitely your wheel bearing and you'll just need to order a new one. if not than it's probably a tire tread issue that causing the hum, you'll need to replace the tire.
+1 beat me to it
Just because you can not feel play or hear grinding when spinning hubs by hand does not mean they are not bad... I also change them out in pairs whenever I change them, if one side is noisy, odds are the other side will be soon too...
are the tires cupped? look at the tread pattern to see if there is high/low spots. Is there camber wear? check these things
No camber and nit sure on cupped but I notced when I make a right turn the noise is normal but when I make a left turn it starts doing the wah wah wah or something but yea right turns steady noise left turns it makes a throbbing sound right rear I want to say
I'm guessing when you make a left turn at speed all the weight goes to the right rear
ok changed one the big hum is gone now i have a quieter hum from the left side.....so both bearings are done lol fuuuuu
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
me and you gon be noisy
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/cuddle.gif.bd1b29c179c0482f8313dbd790b74c94.gif
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
I loved my JVC head unit. Got it for a steal and never had an issue. Pioneer on the other hand, had 2 with constant issues. I installed that Sony...
16
252
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
4
477
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
988
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
inspector3711
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
