How do I add 2 speakers and a sub to the 4 speakers already installed?
  • 3
Immonster
CarAudio.com Newbie
WA
I added a sound bar to my Jeep today. So now I have 4 speakers running. It sounds ok but it lacks bass. I purchased a 4 channel amp and a sub to add to my system. I then remembered I had a pair of Jensen speakers that fit at the base of the roll bar. The head unit puts out 55 watts x4 for the speakers I already have installed. I was hoping to power the Jensen speakers and sub with the amp, but after purchasing the sub I realized it's powered. So how do I add the Jensen speakers to the rear set on the sound bar? Do I hook the rear in series or parallel to the Jensens? The amp has similar power that the head unit has, 50 watts RMS x 4 at 4 ohms. All six speakers are 4 ohms. The sub has 50 watts max power. Or do I skip the head unit all together and run all the speakers through the amp? The advantage there it seems to me is I'd be able to upgrade the speaker wire if I used the amp for all speakers. Right now it's all running on the thin stuff. I have no idea if it's the same as home stereo as it is in cars, but I try to run as heavy a wire as I can. I have had people tell me I'm wasting my money on speaker wire and that I can't hear a difference, but I feel like it makes a difference.
You can use two front channels to power the full range speakers, then use the rear channels to power a sub. IMO, for that price I would rather use...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
3K
I took a quick look at the manual for the Jensen. It only says that the usb is compatible with memory sticks and iPhone and iPod. It makes no...
Immonster
CarAudio.com Newbie
Immonster
WA
Kickstand
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
