How Do I Wire This Sub?
  • 3
JasoninDLH
Jason Was Here
109
31
MN
Just curious how you would wire one 2 ohm SVC sub up to this 2 ohm mono amp which has four speaker wire connections (right now I believe I have it connected to the far left + and far right negative)? Maybe it doesn’t even matter?
How would you wire it up to a 4 ohm DVC sub?
Just use one set of terminals they are both have the same output signal...the dual set is just to make wiring options a bit easier
^exactly.
Each polarity pair of terminals are internally connected on a mono amp, so makes no difference which you use, can use just two terminals, or can use all four if you need to.
I typically wire the subs inside the box, so SVC or DVC doesn't matter in my situations. The wire would be connected the same at the amp, I typically only use two terminals, and then route to the box. Example, a 4 ohm DVC would have the coils paralleled right at the sub to make it 2 ohm, then one wire ran to the amp.
Would something like this work? https://www.crutchfield.com/p_204BTA1010/Bazooka-BTA10100.html
13
4K
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
445
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
871
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
853
JasoninDLH
Jason Was Here
JasoninDLH
MN
JasoninDLH
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
