How Do I Wire This Sub?
JasoninDLH
Jason Was Here
109
31
MN
Just curious how you would wire one 2 ohm SVC sub up to this 2 ohm mono amp which has four speaker wire connections (right now I believe I have it connected to the far left + and far right negative)? Maybe it doesn’t even matter?
How would you wire it up to a 4 ohm DVC sub?
Just use one set of terminals they are both have the same output signal...the dual set is just to make wiring options a bit easier
^exactly.
Each polarity pair of terminals are internally connected on a mono amp, so makes no difference which you use, can use just two terminals, or can use all four if you need to.
I typically wire the subs inside the box, so SVC or DVC doesn't matter in my situations. The wire would be connected the same at the amp, I typically only use two terminals, and then route to the box. Example, a 4 ohm DVC would have the coils paralleled right at the sub to make it 2 ohm, then one wire ran to the amp.
Would something like this work? https://www.crutchfield.com/p_204BTA1010/Bazooka-BTA10100.html
13
4K
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
326
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
820
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
976
JasoninDLH
Jason Was Here
JasoninDLH
MN
JasoninDLH
    Jun 3, 2024
