How does the Banana plug work on Type-R?
Nevalite
Canada
Hey,
I just got my Type R and I want to run them in prrallel to 2 Ohms...I understand I need to use the banana plugs to go + to + and - to - Then run the wire from the amp to the leftmost negative and the positive to the rightmost clip....
I just dont get how to put the little banana plugs in and have a wire in also?
This is what it looks like when I plug them in:
And then if I push down the button to plug in the speaker wire they pop out, they cant be plugged in and pressed down at the same time:
You don't have to use the banana plug... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Or you could wire your send from the amplifier into one of the "jumper" banana plugs...
does it matter if you use the "left most" negative and so on for the positive terminal. Wouldnt they be connected so it wouldn't matter which one you used
It's a dual 4ohm sub, it's gonna have two leads on it. Look at a wiring diragram and wire it to whatever ohm load! You also don't need the bannana plug. Just tie the speaker wire together and your set.
-Nick-
-Nick-
Indeed...
I wouldn't be comfortable using banana plugs on a subwoofer anyway...
i use the banana plus on mine... just push the terminal down and push the plug into the top)like you have it) but you have to push pretty hard to get it down in there all the way, but it does go in like that
I got them in, like you guys said, just needed a little muscle...
So is this right to get 2 Ohm load?
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'm not sure how you actually wire the Type R, but that is the correct general idea to get 2 ohms.
OK I checked this is right, Thanks guys //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
548
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Nevalite
Nevalite
Canada
Megalomaniac
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
