MrBananaMan 10+ year member
My subwoofers and amp work fine together, until I was experimenting one day. The amp is mono, and I have two subs. They are wired with a positive and negative from each sub in their correct channels on the amp (2 positive wires in one channel, each leading to a different sub, and same for the negative side). The polarity and ohms is correct also. The weird thing is that if I unhook sub A, the amp goes into protect mode, turns back on, and goes straight into protect mode over and over again. When I unhook sub B instead, sub A and the amp work fine. And yeah, they work fine when they are both plugged in too.
What the heck is going on here?
second picture is how I am wired: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
