HOW TO PREVENT A XS POWER 3100d FROM SWELLING.
it happens over time to all AGM batteries, duh...when I pulled out my Powerbattery G31's that was in service for 3 years and still was popping 150's....about half of mine were split open.
I've had a SuperStart AGM (rebadged deka) under the hood of my alima for 5hrs now. Has been charged at 15.1-15.2 the entire time with NO issues.
NONE of my dekas have ever done that, seems to be more common with xs under the hood for some reason....
Thank you for the video man, about to put an XS group 24 under the hood of my Altima. That engine bay gets insanely hot. (So much so that when you slam the engine its like having the heater on in the car O_O) Guess thats what you get when you slap a v6 in the same space meant for a 4 :|
All engine bays do this, regardless of engine size.
Well not all, granted my last car was a 95 LeSabre. But I could shut it off, wait 15 minutes, then do engine work. (the engine bay was HUGE, and engine tiny) with my current car. I have gotten burned the next day trying to do work //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I guess its more of a heat retention thing.. and **** its good at it
If you wait 12+ hours and your engine is still hot enough to burn you then there is other underlying issues there.
All cars while being used build up a lot of heat under the hood. There is no two ways about that. Some may have more/less heat over different times, but in the end it is gets very hot under the hood.
With that said, I still never had that issue with batteries even in my turboed cars.
Make sure the fluttering sound you are hearing isn’t something flexing. When I start pushing my subs, the sunroof sliding cover flexes so much I...
29
5K
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
8
185
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
553
loudmofo
loudmofo
Providence, Rhode Island, United States
smoka
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
