how to wire my amp to 4 speakers when stereo only has 2 RCA outputs????
  • 4
bkm48198
My pioneer car stereo only has 2 RCA outputs and I have a 4 channel amp, I have the rear speakers running thru the amp via the RCA cables but don't know the best way to hook up the front speakers to the amp also. I assume I could run wires from the head unit speaker output back to the amp and then from the amp to the front speakers, or I could get a RCA splitter (1 female to 2 males). Can I use both the RCA's for the rear and also hook up the fronts thru wires to the high input or will that cause the stereo to have problems? I know I can't hook up the rears thru the wires at the same time as the RCA's but is it OK to hook up the fronts?
If I use the y spliters won't I lose the fade from front to back ? I would prefer not to lose the ability to have more power from the rear at times and the rear speakers will handle more power than my door speakers.
I didn't think of adjusting the gains. I've 54 and have never been into amps and don't have subs, just have a Mustang with a nice engine and want to be able to hear the radio better over the exhaust when I get on the freeway.
yeah, it'll be hot but off. Just like your tv when it's plugged in.
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
bkm48198
bkm48198
Michigan
bkm48198
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
