how to wire....
  • 4
Here you go:
As you can see, I do not think it is possible to wire 2 X 4ohm DVC subs to a 2ohm load, unless you use an accumatch by veritas.
Originally posted by 85cutty how do you wire 2 4ohm DVC subs to a 2 ohm load, the subs are Alpine type R 1241D
you cant.... you can wire each sub to 2 ohms by putting the (+) to (+) and the (-) to (-) but you cant as far as i can think of put the pair to show a 2 ohm load.
i keep see in other posts and **** that it is possible... something about wiring the subs in parallel or sumthing, it didnt go in to much detail tho....
Originally posted by 85cutty i keep see in other posts and **** that it is possible... something about wiring the subs in parallel or sumthing, it didnt go in to much detail tho....
that is parallel..
ok never mind... if i wire just one of the subs can i only go 2ohm or 8ohm
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
297
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
782
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
954
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
949
85cutty
85cutty
Vancouver
85cutty
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
