FEATURED Hyundai Cilantro.. I mean Elantra!
RF are good amps, bit overpriced in my book, but well made as are JL. But that Jp77 is a beast fo sho! Lots of great Korean board amplifiers out there, no reason to limit yourself to one brand.
True. I do miss US Amps Barbara Ann. Man that thing sounded good!!!
Believe it or not, this 4 channel marine Soundstream Rubicon Nano sounds great too... Guess what, also a Korean amp.
I've seen some interesting comparisons on the Smart and the Smart BASS for sub use, If I was to choose, thinking the SMART BASS would the Taramps I would consider.
If you're wiring to .5 the bass version is the ticket but outside that it's half a dozen in one hand and six in the other kind of thing
I got the little BASS 400 on my test bench and it actually pounds the $hit out of a set of 12's and barely gets warm! Pretty amazing what these little things will do.
Have to remember only about a 4-5 db increase in volume from 1000 to 3000 watts, not a huge difference.
1000 to 2000 3db
2000 to 4000 another 3 db
4000 to 8000 another 3db
So, one has to go to 9000 watts to double the volume from 1000 watts, pretty steep hill to climb.
Weird that you mention Techmaster. I was pounding Techmaster when it kept shutting off. Bass Computer!!!
Maybe try backing your gain down some and see if it does it again. Personally I'm not sure how much I trust the clip light to be 100% accurate
Check out machines 2020...it's amazing 🥰
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
195
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
485
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
664
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
12
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
spokey9
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
